Re: Alky Control
the number knob is how much comes on- that is adjusted to where your boost level and where knock come in.- that needs data master or a scan master to best determine
the push button is for it to test itself indicated by a little light prolly on the gauge pod near boost- push it at idle and the truck will bog if working.
only have GN settings and mine comes on around 7 because of 24-26-lbs of boost without knock.
