Axle offset to the right...?
six_wheeler
Guys,
The rear axle seems to have crept to the right - the right wheel sticks out a bit while the left is a little tucked in. With speed, the vehicle seems to fishtail, especially once I lift off of the accelerator. I just had the leaf bushings replaced and did the wheel alignment. Any suggestions?
TIA,
Shady
Timbo
SyTy Stalker
Re: Axle offset to the right...?
This stance is pretty normal. I doubt it's what's causing the fishtailing.
Daryl H
six_wheeler said:
Guys,
TIA,
Shady
If you do a four wheel alignment, it will tell you which way the rear axle is pointing.
Timbo
SyTy Stalker
My truck is like that, and probably at least half of the other Typhoons that I know of are too. I don't think it's actually the axle, but the body itself is offset.
Loeryder
Mine is off too.
About a 1/4" to the drivers side.
I actually have spacers on the rears for my Zo6 wheels and am considering running a 1.5 spacer on one side and a 1.25 on the other to even it out.
six_wheeler
But my major concern is what's causing the fishtailing - especially immediately after I lift off the throttle! Any probable causes?
TIA,
Shady
mattw
Loeryder said:
Mine is off too.
Is there any adjustment in our body mounts? Could they just be loosened, straighten the body out on the wheels, then re-tighten?
-Matt
