Well got a DBB 60-1, stock stall, 50's, vortecs, 412, ITS minigate, open dump. I tried to build boost and all i could get was about 1-2#'s out of it and it took a little while. As far as from a roll its not to bad, takes a few seconds if there is no downshift. The gate is set up to only run base boost right now, so it opens a little as soon as it starts to build boost. So with a controler on it, it might spool even quicker. Its really not that bad, it only takes a mabey 10ft before it starts to climb, and like i say i think it will be better once i get a controler hooked to it. Now if you are planning on doing racing go bigger stall, a lot bigger. I am thinking at least 3200 mabey 3500. That way if i ever go bigger the stall will already be there.
