Re: base boost with minigate and stock turbo 5-7psi?
Well , the main thing is that the stock #8 turbine is very small and there is a lot of back pressure that helps the gate to open sooner
With a stiff spring the "cranking" point goes higher. Cranking point is the point that your gate opens, that is lower than your boost. In your case id say it starts opening at 4-5 psi
When i installed a very stiff spring my boost became SOLID .
My base boost is 22 psi though
