what would cause rod bearings to fail? only two rod bearings went out. i figured while i was in there, might as well replace all the bearings. the rod bearings wore just a little bit down to the copper underneath. the engine was making a terrible racket. the crank looks fine.
maybe an oiling problem? i change the oil every 3k with synthetic. 2 cranks broke in this same block. i wonder if the block is messed up causing the bearing failures. any ideas?
