Best shock to go with on a Typhoon with stock suspension?
Syclone#1992
SyTy.net Moderator
What do you recomend? I still have the original shocks all around and want to replace them with something decent. Don't want something that will beat me to pieces, but don't want something too soft.
What do you recomend? When replacing the rear shocks, do you have to go with the air pump type? My compressor still works in the rear, and I wanted to know if most of you unplug them when you replace the shock, or if you buy a shock thats compatable...
Any help appreciated...
TYHOGG
I used the KYB gas-s-just. they are awesome. $38 a piece at Tirerack. If you use any of the KYB's the ELC will not be used. You can unplug it through the rear drivers side wheel-well. I just unplugged mine mine and tapped all the fittings up.
TYRODD
My ass. Look at it.
I just removed the whole thing today :) . I had no idea the elec. harness ran all the way to the firewall, thought it would be shorter for some reason. Prolly 15~20# weight savings including the compressor, sensor, and harness :rock:
Jer
Don't taze me bro!
Do you guys recommend the same KYB Monomax for trucks that are lowered too or is there something else that people use? Thanks.
TYRODD
My ass. Look at it.
If you lowered you truck with blocks the KYB's will work fine, since the suspension travel didnt change. If you used drop springs, it may be a better choice to use drop shocks.
Baja Resident
KYB makes drop shocks as well. Thats what I used since I went with new belltech springs. I think I posted the pn# in another post.
Jer
Don't taze me bro!
That's what I figured. I need to check w/the previous owner but I'm pretty sure he used blocks. Thanks for the info.
Is there any special part number I need for our application or are they a universal fit?
Jer
Don't taze me bro!
Baja Resident said:
Jer said:
TYRODD said:
hey Jer you can just duck underneath and see if there are large blocks between the axle and springs, no need to ask him
I thought about that too after I posted that. I got about 4hrs of sleep the night before and wasn't firing on all cylinders at the time of the post.
Andreas
Re: Best shock to go with on a Typhoon with stock suspension?
Andreas said:
With a lowered TY with torsion bars is still the monomax KYB-565048 that fits?
Must been drunk when I wrote that !
What I mean is: Does the KYB-565048 fit a torsionbar lowered TY, or is it just for stock ride height?
QUICK STORM
B.A.M.F. BMW Tech
first part, yes:tup:
second part, no:D , it will fit stock and lowered torsion bar trucks. only way you would need a drop shock for the front is, if you used a lowering lower control arms, which we cannot use due to the spindle.
98LowS10
when i went and got my Monomax's from the local speed shop, the guy showed me that they are sold in two variations for the 4X4 s-series suspension. 0-2" drop and lifted.
so these shocks are rated from the factory to provide up to a 2" drop up front with no problems.
hideakimura
NipponSyTy
Hi Wes, can you post the PN again? cause I couldn't find out...
