thewumpus99
My boost won't go higher than 7 or 8 psi, even at WOT.
I took the attached .CSV log using TunerPro RT:
https://docs.google.com/file/d/0B0w-JDdb37U2MG9PRUkzMTdHdms/edit?usp=sharing
Chip came from Waller when he rebuilt my engine, and should be matched to the build. I'm pretty new to TunerPro, so not sure which of these things is normal vs. which is cause for concern. Hopefully you guys can help with that! Anyway, the things that seemed weird were:
1. It seems like “MAP 3-bar kPa” is stuck at 2.2 the whole time, whether idling or WOT on the highway. This matches the “Base Desired Boost Pressure 3 Bar (kPa)” value, but... shouldn't it be changing? The “Desired Boost PSI” of zero likewise seems bad.
2. Why is “Desired AFR” always 0? This should be a closed-loop chip, so shouldn't this value be in use?
If the “Desired Boost” values aren't the problem, any thoughts on what I should check/try next?
Thanks!
Thanks!
