Brake line questions??
Skyhighsami
GMC Typhoon #1308
A friend and I was talking the other day, if you ordered a set of new brake lines for a Chevy Blazer/Jimmy preABS could you replace the brake lines from the master cylinder to each location? I was thinking about when I did the LS1 swap and the Hydroboost getting brake lines either made or just getting brake lines from a preABS truck? Just a thought because I plan to replace everything dealing with the brakes. Thanks
Flyin Ryan
hated cuz he drives fords
Re: Brake line questions??
I got my abs delete lines from hood but I remember others suggesting finding any s truck in the local junk yard that didn't come with abs and grabbing/using those lines which sounds like what your asking right?
jjorgensen52
NHSTE - I'm the only one!
Another place to look is www.inlinetube.com .... they have the setup to do S-10 lines, and they ought to have a copy of my lines since I had mine all redone in stainless about 2 years ago
mattw
Holy crap those lines on LMC are expensive.. jjorgensen52 how much did you pay for your stainless setup.. Mine are looking pretty crappy/rusty and I wouldn't mind replacing them with some stainless lines.
EDIT: I looked at their website and I think they are $185...
http://www.inlinetube.com/Preformed Lines/Web Line Listings/CT-CAT-18.htm
I would def want a set for a non abs setup and I didn't see any mention of that on their website.. Are yours non-abs?
Thanks,
-Matt
jjorgensen52
Thanks,
-Matt
Mine were done for ABS, but the only difference between the two is one fitting, you could just have them change that out. I forget the size of the top of my head. I think I ended up paying about $420, but I also had all my fuel lines done as well, and that's another 3 full length lines :eek:
Skyhighsami
GMC Typhoon #1308
That is what I am planning to do. I have started ordering some stuff I need to get the truck right. The next couple of things to do is brakes, find out why the cruise doesn't work, fix the AC where the previous owner removed it to install the PTE-51. I just need to deside what I am going to do for a master cylinder. I would like to do a Hydroboost but when I do that I am going to swap to a ZQ8 steering box.
Skyhighsami
GMC Typhoon #1308
Thanks for all the help, so far every question that I have had has been answered on here. This site is awesome.
