Brakes Sticking & Grabbing
Michael
Looking for advice on the following:
My Ty has ~148k miles. I live at the top of a steep hill (900' elevation change over ~1.5 miles), so my brakes get a workout every day. I do my best to let off the brakes on the less-steep sections to let them cool. For the past 2 months, I have had the brakes stick intermittently when stopping. I am pretty sure it is the left front wheel which sticks. It locks up prematurely on wet pavement, and tends to pull the vehicle to the left on dry pavement. It is similar to the behavior you see on drum brakes when they have had gear oil leak onto them (getting very grabby). On some of the stops, the brakes stay stuck even after releasing the pedal. The vehicle feels like the parking brake is on, and after applying enough throttle it pops loose. This behavior seems much more likely when the brakes are warm. On ice, the ABS kicks in and leaves me unable to stop the vehicle (since the LF tire skids, it keeps me from getting any brake pressure to the other 3 wheels). I replaced the rotors and pads about 10 months ago (well before this problem started), to address a pulsing I was feeling on braking (apparently warped rotors). I replaced the LF brake caliper 2 weeks ago, and the problem disappeared for a few days. I replaced the brake pads 3 days ago, and similarly the problem disappeared for 2 days.
Does anyone have any ideas? Could the ABS valving be causing the LF caliper to stick? I would have thought that the ABS system would be designed to always allow fluid to release, and only prevent the application of pressure when modulation was necessary. As it's looking like snow coming up, I will try electrically disconnecting ABS to at least allow me to stop.
Thanks,
Michael Pliska
1992 Ty
ty166
Re: Brakes Sticking & Grabbing
replace the left front brake hose (i would do both ) but that will most likely fix the problem. to check the hose , get the brakes warm, make sure you are able to open the bleeder. then bump the peedle until the caliper feels like its hanging up. then crack the bleeder. if fluid squirts out like its under pressure and the rotor now has less drag on it , then its a restricted hose. restricted hoses happen to be common but are often thought to be fozen calipers.
Don W.
X3 The calipers ride on a couple of pins. Where those pins fit into the calipers needs a bit of lube. Like women, to each his own but I use never-seize. Do BOTH sides. Snow or salt? make sure the pins are completely free before reassembly. If this doesn't work and it's ONLY the left front then you have a frozen piston and need a rebuilt caliper. In that case it's prolly a good idea to, again, do both sides so they clamp evenly. If, when you you replaced the pads you pushed the piston back into the caliper without using the bleeder (in other words the fluid went back into the master cyl) you may have trashed the ABS anyway.
ty166
he said he already replaced caliper on left front. i'm assuming he would have lubed the slides when he replaced the pads and rotors the first time also when he replaced the calipers. if seen many vehicles where people have misdiagnosed a bad hose as a bad caliper and two or three rebuilt calipers as defective and brought it to my shop only to find out it was a bad hose. also a restricted hose makes that caliper always stick slightly, thats what may have caused it to start pulsating in the first place. could be either one but i'm leaning towards a bad hose seeing what he has done already. and yes don way right , pushing brake fluid back up to the master on ANY abs is WAY bad......
Don W.
Interesting on the hose, just not something you'd think of every day. Missed the part on replacing the entire caliper. IMHO still; what you do to one side you should prolly do to the other. Whatever is really wrong the other side is not far behind.
ty166
like i tell customers, " the left would be a required repair , the right a suggested repair. but when is the last time you went to foot locker and bought only the left nike ? " true, one side has been everywhere the other has been, but alot of people dont seem to have that reasoning.
Michael
Yes, I lubed both caliper slides on every brake pad replacement, as well as on the new caliper replacement. I always bleed through the bleeder when pushing back the piston for new pads.
I was planning to replace the right caliper as soon as I have a spare moment (I also agree about always replacing in pairs). One item which may or not be relevant - the LR brake cylinder started leaking 11 mo (10k miles) ago, and I replaced only that side (also have it on my to-do list to replace the right side there, but going thru a messy divorce and taking care of a pre-schooler while working many hours).
The hose is interesting - do you usually see it as a kink causing such a restriction? IIRC, it is an assembly which includes a length of hard tube as well, so either the hose or the tube could kink. Hopefully this brake hose assembly is readily available as a replacement.
Unfortunately, the sticking is intermittent enough that I have never gotten it to happen while I am in a spot where I can pull the wheel and check. The last couple of times it stuck, I popped into neutral and the relaxation of the drivetrain was enough to pop the brakes loose (so I may not have even gotten a chance to jack the thing up even if I was in my driveway).
Thanks for all the input, and I welcome any more!
Michael Pliska
ty166
the hose may show no evidence of being bad on the outside, the problem is internal to the hose, so you can have a hose that looks great but is bad. they look good on the out side but the problem is on the inside. the hose replacement is easy, if you can handle a caliper replacement you can handle a hose replacement. the hoses are cheap , probably less than you paid for a caliper. the hose is just a short rubber piece , brake line connects on the one end and the banjo bolt on the other. intermittant problems.......everyones favorite. lol good luck and keep us posted....
Michael
I think I finally have it fixed. Things always make more sense in retrospect! Turns out I had two separate problems which were confusing me with the symptoms! Problem #1 was a sticking LF caliper, which was causing part of the grabby feel (and presumably caused the previous rotor to warp). The remaining grabby feeling (and outright sticking after stopping) was caused by a LR brake shoe which had literally come apart. The lining was split cross-ways about halfway down the front shoe, and apparently the broken-away half of the lining was remaining stuck to the drum after a stop, making use of the "self-energizing" behavior of drum brakes.
The only brake shoes I could find late at night were cheapo bonded ones. IIRC, the cheapo bonded ones were advised (along with getting two sets and using only the longer primary shoes) to help hold the truck for high-boost launches. I will probably go pick up a second set and make the swap before I wear in this set too much. I suppose I should also go back and make all the prior changes symmetrical (put in a new RF caliper and RR wheel cylinder)...
Thanks and regards,
Michael Pliska
