Bunch of parts
blk00z28
Forced to by choice
No one wanted the package, so here's everything parted out.
Add shipping to all prices(which I will get quotes for on heavier stuff, most everything else will easily do the flat rate boxes/envelopes).
-Bowtie Heads
p/n 1404883 (Raised runner 23*) 60cc chamber, 2.00 intake, 1.60 exhaust (don't remember make, sorry), Comp 98541 dual springs, Viton 11/32 Seals, Jesel shaft mount 1:6 rockers(with brand new hardware and brand new rocker rebuild kit) Flow (i/e) 6" - 280 - 205 - $1,400.00
-Brodix intake
p/n - 10093314
This intake is not ported!
Comes with fuel rails, 1" spacer and forward facing 90* plenum.
It has been milled on the china wall flange .010" to clean it up.The ports have one bead of weld in the top side of the port to make fit the above "raise runner" head. You will need to mill the runner gasket surface due to small amount of weld protruding from the runners(this is a 15 min job for a machine shop and might cost $25) and possibly polish(or port) the added material in the runner.(it WILL bolt on any 23* bowtie/brodix/pontiac head perfectly). - $525.00
Comp Cam (brand new in box) gross lift(i/e) .538 - .531, Duration(i/e) 224/224, Separation 115 - $215.00
-A2A 20"x11"x2.5" IC (it is 30" long from tip to tip) - $95
-Victor Reinz short block gasket rebuild set - sold!
-Jeep steering shaft - $25
-Taylor spark plug wires & taylor spark plug wire boots - $75
-Mini starter - sold!
-Accessory brackets-the set-(power coated black) - $95
-MSD hei coil - $35
-MSD digital 6 connector - sold!
- ARP head studs - sold!
-ARP intake bolts - sold!
- Cometic Head gaskets - sold!
- RPM 23* sheet metal perimeter valve covers - sold!
- Billet weld on oil filler - sold!
- Billet weld on AN male fittings - sold!
- Intake gaskets - $30
- RPM sheet metal 100 degree sideways facing plenum - sold!
- 90mm Accufab throttle body - $sold!
- (6) used 75# low impedance injectors - sold!
- Comp Lifters for 4.3L - sold!
- Edelbrock double roller timing chain - sold!
Pictures of everything:
Slyclone
Well-known member
Re: Bunch of parts
I was wondering if it came with the lower intake manifold gaskets, the intake plenum gaskets.. that sort of thing. I was not sure if the kit came with head gaskets, valve cover gaskets, timing cover.. seals.. so on.
blk00z28
Forced to by choice
Re: Bunch of parts
Oh my mistake, I listed the wrong gasket set thought that was the other one. it's just the short block gasket set. With oil pan, water pump, those kinda gaskets. I updated the main post.
Darin
Re: Bunch of parts
Shipping of the mini starter to edmonton, Alberta, Canada t5z 2y5? I'll likely take it regardless.
atomicmecha
I hate rust
Re: Bunch of parts
Interested in the MSD connector, the double roller chain, and I have a question about the arp intake bolts. which bolts are they? the ones that hold the upper intake to the lower? If so, I'm interested in those as well. What would shipping to 20874 be?
edit, sorry, :oops: i think i may have answered my own question when i saw the pictures could be enlarged, its the arp 434-2101 package right? So they are for the lower intake bolting to the heads. Still interested in them. :tup:
blk00z28
Forced to by choice
Re: Bunch of parts
Yea, they are lower intake to head bolts. I'm carb style so I didn't need upper to lower's lol. I'll pm you.
SEL777
One of 101
Re: Bunch of parts
Do you have a timing chain cover (a non-stocker one)?
Will the Cometic head gaskets work with Vortecs? Since you're running Bowties.
blk00z28
Forced to by choice
Re: Bunch of parts
Dibs on cam, head gaskets, intake gaskets, and maybe short block gaskets.
PM w/shipping to 80206 pls.
I sent you a pm, check it.
Bump for sale on other parts. Make offer on stuff. I'm closing the post here in a few days seeing nothing is moving.
