I forget what is exactly need, but If remeber righ tit needs the new style spindlea nd some work to make the abs shields fit, but don't quote me on that.
IMO I think the dual piston upgrade isn't worth it for syty's. The brakes will still be 10.8 rotors and in your case braking will probably be messed up because the rear ls1 brakes are 12" which are probably stonger than the fronts...You will be spending a lot time for brake that will still be undersized. I would save you money and put them torwards the Baer setup. However don't let me stop you, if you wanted more info I would go to one of the s-series website and see what is need to add the calipers to older 4wd vehicles.
