Falco
Howdy,
Since my rebuild this winter (new L35 heads, rockers, springs, pushrods, 50's, PT52, Innovative WG) I can hear a clacking noise when I'm on the trottle. I can't hear the noise when the turck idles, or when I rev it up in P or N or when the truck decelerates. It seems to be RPM related. I thought this over several times, here comes my "mental path":
*Since I can't hear it at idle it's not a valvetrain noise, even if it's sounds like it
*I thought it's an injector tick, so I moved up the fuel rail and all the injectors to the highest position. The noise is still there...
*Exhaust leak? Can an exhaust leak sound like clacking!? I'm using copper SCE header gaskets, which fits like sh*t so there could be leak(s) there and I've a definitive leak at the end of the downpipe. Any experience with the SCE gaskets or with sounds caused by exhaust leaks are appreciated...
*The truck idles great and performs acceptable beside it has serious spark retard, I guess, because the knock sensor is picking up the same noise (I've no real knocks according to the spark plugs, no lean conditions etc)
*The noise seems to be there only when the engine (drivetrain?) under some load or from an other viewpoint when the timing is not so advanced (is this a good though?), but I'm running out of ideas, so pls HELP if you can!
TIA,
TIA,
