carVSsuv
I have had my VIscous coupler fail in the lock up position and broke the front propshaft. So after reading and searching in found people recommending cobra transmission parts for the TC. So I order the rebuild kit and a new vc and put it in and found that the truck would idle and move but the minute I gave a little gas it would slip to the from output. I didn't have the prop shaft in as the truck should move fine without it. So eventually the truck would not move and it would just spin the front output. So I called cobra and they were good and sent me a replacement. Got the replacement and did the swap. I did the test with the TC on the floor and the Vic would turn at about 30ft lbs. Well shit, put it back together and then got the truck back together and went for a drive. Well it moves better and under light throttle drives but the minute you go a little more it just transfer power to the front output again.
Am I missing something here?
Both the replacement Vc came from cobra and I am very curious if anybody else has had these same issues with these parts.
