Code Help?
Jeremy
I have 2 codes:
12-No reference pulses from distributor are reaching ECM.
42-Electronic Spark Timing is grounded or open, Malfunctioning HEI module can this.
Any ideas or help would be greatly appreciated.
SY2932
Administrator
Re: Code Help?
Check this out.
Code 42 could be from this being disconnected:
"The ESC Electronic Spark Timing "tan wire with a black stripe" that everyone can't find when attempting to set their timing (s-series). Wire is under the carpet on the passenger side below the heater box. It is disconnected to set the timing, then reconnected."
