Crankcase Vapor Burn Off
sabredog
I was going to install a weld in barb fitting to burn off oil vapors coming through dash from drivers side valve cover vent. Question is ,do I need to put some kind of check valve in the vapor line to keep exhaust from pushing up the vapor tube back into the engine?
Thanks
Loeryder
Re: Crankcase Vapor Burn Off
I think you are referring to welding a slash cut bung into your exhaust system.
If the slash cut tip is welded at an angle the exhaust rushing past the opening will create a vacuum.
I know it is a Honda page, but this guy tested various methods of PCV scavenging.
http://www.honda-tech.com/zerothread/1199935
About halfway down his post is a title "Exhaust slashcut evacuation"
He claims Moroso makes a kit for this exact purpose.
FYI You need a new motor, to fix the problem the right way. You have a melted/broken piston or broken piston ring.
sabredog
sounds like there are alot of bad motors out there with the number of pcv valve posts for vapor issues.
sabredog
cavscout, that is the system i'm talking about.Anyone know where a good place to weld the venturi tube in.How many inches in front of the cat. conv,?
The problem is your driverside is suposed to be where you air enters from the PCV system, the passenger valve cover under vacuum is where its supose to exit. (You should atleast make sure you have 2 PCV valves on that side) It sounds like you have excess Crank case pressure, the pasenger side is probably not keep up. If you really wanted to you could probably tap off the brake booster hose to add a 3rd PCV valve as a bandaid to the situtation.
sabredog
I ordered new pcv valves from GM parts dirrect, 799c also ordered a drivers side screw in breather and the moroso crankcase evacuation kit 25900. There is no smoke coming from the tailpipes during start up or while idling and when I replaced the spark plugs they all had a nice tan color to them, no sign of burning oil.
