Datamaster trouble shooting
Ty 1450
30psi on 93 oct (boom)
I cant get my datamaster to link up with my aldl, i set the com port and when i hit start. It goes into No pcm syn in yellow and just counts up. I disconnected the cable then it went to the Red warning saying loss of connection. So i know the connection is good, but it does not want to link up and start recording data. Any ideas? trying to get this beast up and running again.
Rudy
RJE 93Green/Tan
ty high on psi
Re: Datamaster trouble shooting
did u try changing the port?? at the top of the window go to setup and change the serial port to which ever one your is in. then hit "test com"
Ty 1450
Did the test comm. this is what popped up on the screen. "The aldl adapter is working, and unkown data was detected. This may be an unsupported PCM type". Not sure what this is, everything was working fine last year before i blew my engine and had it rebuilt.
Ty 1450
got it up and running, changed usb to serial cables, then changed port i was plugged in. After that i started dm like 5 times and it started working....go figure
Rudy
I had the same exact problem on a fresh install of DM on my laptop. The first thing I did was the old standby trick of re-booting windows. I rebooted and started DM and then it's been working fine ever since.
