DB9 to USB Serial adapter
Captain Morgan
Moderated User
well, as my shitty luck would have it, I got my Datamaster cable on Friday.....looked at it today, and realized both ends were female. So, i go to radioshack to pick up an DB9 Male to Male adapter. Well, I get everything setup and realize this supposed serial port on the back of my new laptop is a 15-pin monitor connection, not a 9-pin serial port. Soooo, now WTF do I do. I ask my friend (who is a little more computer oriented than I) if a Parallel port can be setup for a Serial port, he said nope, I need a Serial to DB9 adapter.
Anyone else run into this problem? probably not, nobody has as shitty luck as I do, but if someone has, got any tips for an adapter or place to buy one.
Sy769
I did the exact thing. Guess I should have looked a little closer at what that port was. Do a search you can find a lot of USB to serial port adapters. I remember one I saw for about $35.
Captain Morgan
Moderated User
ok, well i have found adapters like that. but it has also been brought to my attention that a 9pinDB to 25pinDB adapter might work, and just go through the parallel port. any idea on that one?
GMC-YA
Well I have some good news but mostly bad. I ran into this problem about a year ago, and tried the Belkin USB adaptor, with no luck. So I called TTS and ask them, they said they are working on the problem and basicly it has nothing to do with the adaptor its the software. They all ready have a beta test program out for the Belkin adaptor but guess what, its not for the syclone. At the very bottom of this page you will see what I'm talking about http://www.ttspowersystems.com/dm_dload.htm I got tired of waiting and bought a cheap laptop for a hundred bucks, from a guy on syty.org. HTH EDIT: The only other option I see if your computer has a PCMCIA slot, then you could do this, which I didnt even think about till after I had bought the laptop, but the old laptop was cheaper so its up to you. http://www.amazon.com/exec/obidos/ASIN/B0000512MH/002-7680929-2639211 Parallel will only work for Diacom, as far as I know there is no way to use, and believe me I was willing to try anything.
Rufus
The Belkin F5U103 USB-Serial adapter will work with the current version of Datamaster-TT, but you have to go to the recording screen Options - Advanced menu and make the "Disable CCM Handshake" setting. You may also have to play around with the ALDL Serial Communication - ALDL Link Timing setting to make it work.
Note that many USB-Serial adapters do not work at all with any GM OBD1 ECM's because they do not support the 8192 BAUD rate that is required.
Hopefully, the DM update will be out by the end of the year!
Gary
z28camaro
Or you can get a port replicator for your specific laptop from the manufacturer. That is what my father ended up doing when he realized his VIAO didn't have a DB9 port. Not a cheap way to go, but it works.
BigBadSmoosh
morgan - a port replicator plugs into the back of your laptop, and has "extra" ports on it, mostly video/serial/usb/keyboard/mouse ports..
they arent cheap, list what kind of a laptop you have and ill find one on ebay.. or I might have one..
Usb -> serial doesnt work all that well, but it might with the prementioned suggestions..
id say a port replicator is your best bet at the moment..
InvisiBill
Serial and parallel are two completely different beasts. You can get adapters to make the plugs fit together physically, but it won't work no matter what you do. It's just like diesel will fit in your gas tank, but it just won't work right. This was discussed quite a bit in my cable thread in the GP forum...
I'm not an expert by any means, but it seems like once the ALDL data was converted to serial, the baud rate of the ECM wouldn't really matter. If you have a Best Buy there, just get a USB-DB9 adapter and see if it works. If not, just return it and you're a little bit wiser for your time and gas money.
A lot of port replicators supply power to the laptop as well, through an AC cord. I'm not sure, but at least some of them might require power themselves, which could be a problem in a vehicle.
Captain Morgan
Moderated User
as stated a few posts up by smaug, i cannot use a port replicator on my computer. as usual, shit just sucks for me.
Sy769
Pulled out my adapter. It is the Belkin USB to serial adapter. Works fine for me. Like I mentioned before I have seen some for cheaper on one of the datalogging software sites similiar to datamaster. I assume you have USB ports since you don't have serial. If not I dunno :banghead:
Captain Morgan
Moderated User
yeah, i got USBs, i guess i will go to best buy on Wed and see what I can dig up.
Rufus
InvisiBill said:
I'm not an expert by any means, but it seems like once the ALDL data was converted to serial, the baud rate of the ECM wouldn't really matter. .
Bill, the baud rate is established by the ECM and the USB adapter must match this (Datmaster tells the port what baud rate to use). Many USB adapters will not switch to the correct baud rate needed for the GM OBD1 ECMs, and thus will not work. Belkin does work, I have tested then!
The USB adaptor collects the serial data at 8192 BUAD, then it is converted to a much data rate (1 to 12 MB) for transmission to/from the PC.
HTH,
Gary
InvisiBill
Yup, that's the same thing, but another brand. Apparently some work and some don't, from what people have said...
Nothing was posted about you not being able to use a port replicator... If you have a big funny connector on the back, that's what it's for. There are also some "universal replicators" that plug into the USB port and provide all the other ports. But you'd run into the same thing, where some brands' USB-DB9 might not work right...
Captain Morgan
Moderated User
i could have sworn i posted about the replicator. either way, i dont have one of those things to plug that into either, so thats out.
Best Buy is on my list tomorrow, they have the Belkin adaptor, and ill see if they have a cheaper one too, which ever one works, ill keep. (that is IF it works)
