dc fan controler q's
gjp
another post whore
I am installing a DC controler for my fan. Turns out the guy who builds them lives 10 min from my house.
1) Anyways there is a blue wire that is suposed to connect to the Ac compressor. The compressor has 2 wires. (black and green) whitch one does it go to?
2) is it better to hook the yellow to a constant hot so the fan stays on after the truck is off to cool it down?
Thanks
4C FED
Absolutum Dominium
Re: dc fan controler q's
Thanks
I used to run a Black Magic fan & it used the green wire as the trigger for the fan to run continous as long as the AC was on.
pinellas50
New Guy
There are very specific instructions that come with that controller. Wire it as it says.
I had one on my old V8 Ranger. It's a great controller. I wired it so everything shut down with the key off. I didn't see any advantage having it cool the radiator of a non running engine. But that's just me.
As for your A/C question. Track down the wires that go to the pressure switch for the system. You want to tap into the wire that is always hot as opposed to the one that has power only when the system isn't at high pressure. If you wire into the compressor's wiring, your fan will turn on and off when the compressor does.......= not correct.
gjp
another post whore
instructions are not clear. They just say "connect wire to compressor wireing so the fan runs at 50% when the compressor is on".
I noticed when I turn of my wifes car the fan runs for a few min. with the engine off.
pinellas50
New Guy
OK. Gotch ya. Wire it as I said and you won't be dissapointed.
I never did like that the fan only ran at 50% with the air on. It's freakin hot down here! You can put in a jumper to get it to turn 100%. I think it's the jumper that is for under drive pulleys.....it should be in the instructions.
And it's really up to you on the whole fan running with truck off thing. I know that can be a problem with some types of alarms....but I think that is in the instructions also and I don't know the specifics about that problem. I just remember reading about it.
Good luck.
gjp
another post whore
did not think about the alarm...Have to check that. Thanks for the help. The kit was good. Everything was included. I do have underdrive pulleys so I jumped that conector.
Windedv6
Ty n 10s
I use the model that runs my electric fans as well as my electric water pump. I can flip my key to acc and have the fans run and circulate the water in the block at the same time with the motor off. The controller keeps the temps steady.
John
Maxtor
I hope they are still available, great controller. I can't get the link to work either.
Mine is wired up to shut off with the key, not sure the value of cooling what is in the radiator unless you have an electric water pump to circulate the coolant like John has.
Flyin Ryan
hated cuz he drives fords
Brian Baskin who is the owner and maker still makes the controllers but is so far behind on orders that he took the site down for now until he's caught back up.
gjp
another post whore
according to the web site he is 10 min from my hose. Maybe I should go over and help him make some. I used to be an electronic tech. years ago.
4C FED
Absolutum Dominium
Yeah, I was hoping to buy one for use with my fans & electric pump setup.
Flyin Ryan
You should man... I've only gotten in contact with him via email from his site.. it took him about a week and a half to reply back to me so shoot him an email about it
Syclone Rob
Its all ABOOT the SYTY eh
I have this controller.. Works awesome and as advertised. Even a couple of buddies have it and works great.
pinellas50
New Guy
I saw that he took his site down. I started going through the ford sites and a lot of people were talking about not getting them quickly or having trouble getting in touch with Brian.
On a side note, Brian had excellent customer service back when I got mine. I have nothing but great things to say about the product and Brian. I hope he keeps them coming!
