Distributor 5V Signal - Help
ghettosled
SYTY SUPERSTORE
Re: Distributor 5V Signal - Help
not getting 5v anywhere.. (atleast in MV setting, i dont have a scope to measure squarewave) i disconnected the harness from the ecu and distributor and checked ohm's to ground.. no change, so no grounded wires.
when i connect the harness to the distributor then all the wires are grounded per the ohm readout on the fluke meter. I get the same readings as if i check the ignition module on the bench not connected to anything) i checked for 5v at the white wire and the tan wire during cranking and running condition, and got nothing. The only thing i see is the white wire is pulled to ground and does not "un-ground itself" up above 400rpm like it should (or what i believe should be happening) Doesnt the white wire need to "un-ground" itself in order for the ignition module to switch over and let the ECU control the 5V to the tan wire, thus advancing the timing?
FYI, i also looped A&B terminals on the aldl and have a flashing code 42 (to no suprise)
The_Bronze
My scope was dead, but I grabbed my meter and checked the BYPASS connector in it's different states.
The PCM sends a (in my case) 4.66V steady signal once the RPM rose (won't know actual RPM without a scope). If I disconnected the BYPASS connector both sides read 10-30mV on each side of the connector. I would guess that until the module releases the EST wire from ground, the PCM takes over control and verifies that by sending the 5V on the Bypass. If the module doesn't see the bypass back, it goes back into base timing. Also, when I disconnected the EST connector I saw 5V for a second before it disappeared and never returned, even with multiple key cycles (quick in succession). I would be doing all the diagnosis with the EST connected and I would be focusing on the reference and EST lines. I'll compare the scope readings and meter and see what kind of average voltages you can use to help determine what the PCM is seeing.
I'll pull the PCM loose and scope out the reference, bypass and est wires and see how they react with each other. You have me curious. I'll print the waveforms and the explanation soon.
turbodig
As has been mentioned before, bypass goes high as soon as the ECM deems the engine "running".
Ref will pulse with distributor pulses.
EST will "follow" the ref pulses (ie, be sorta sync'd to ref), but the pulse width will change proportional to dwell, and the relationship of the trailing edge of EST to REF will vary with commanded timing.
The falling edge of EST is what commands the actual "fire". The longer the duration between the falling edge of EST and the oncoming REF pulse, the more commanded advance.
REF gets generated by the module, from the magnetic pickup.
If you can get a scan tool to connect, I'd check to see if the REF flag is toggling when cranking, and if you're getting RPM. If it isn't, you're either not getting REF from the module, or it's not making it to the ECM.
Is there full battery voltage to the ignition module? Module grounded?
ghettosled
SYTY SUPERSTORE
yeh, so you only got the 5v on the bypass wire for a second as well.. same with the trucks here that run fine.. the one with the problem has nothing, not even for a split second.
ghettosled
SYTY SUPERSTORE
hey Dig, thanks for chiming in.
The scantool will not connect (atleast the last time i checked, and nothing has really changed since) When the truck ran fine, it would connect and stay connected with my jumper setup right off the ecu.. if connected to the ALDL it would bump offline under WOT.
So lets assume i cant get the datamaster to connect. What signal or info should i be seeing on the reference(white) wire from the module? I have a feeling i'm not getting the right signal here, and therefore nothing is telling the ECM to switch 5v to the bypass wire.
i'll check for full 12v and ground at the module tomorrow... pretty sure these are fine, but i have no actual data to prove it yet.
i have a buddy who is a GM tech coming over to hopefully shed some imput as well.
thanks again.
The_Bronze
That occurs only when the bypass is disconnected. Once it was reconnected it stayed at 5V (4.66V) once it was running.
To go back to a diagnostic solution, and forgetting everything that has been posted except direct observations. Also getting rid of scopes and the cool stuff...
Engine fires up and runs. That takes a lot out of the equation. Replacing 3 PCMs and 3 Distributors also limits what can be wrong.
Powers: A test light will do, but an actual meter reading while running would be best.
A-6 Keep alive. 12V ignition on.
B1 and C16 Keep alive circuits. Battery voltage at all times.
Grounds A test light will do. I don't trust checking grounds with a meter, as people usually think of 0.00V as a good ground, but is an open circuit. All grounds have a voltage drop, even if it's 3m-10mV (Common for good grounds). The test light will do, especially since the main actuators (Idle motor, relays, injectors) are already working. Put the ground of the test light on the battery positive and probe the following (the light should be nearly bright as when you test it on the battery terminals)
D9 (ignition) CHECK THIS FIRST If the EST circuitry doesn't have a ground, then module timing is all you have, without proper signals to the ignition module from the PCM. This could also be used by the PCM for communications, but that is just a guess.
C13 and D7 (injector grounds) The vehicle is running. These aren't a problem.
B5 and B6 (sensor grounds) The vehicle is running. These aren't likely a problem.
D1 and A12 (main power grounds) CHECK THESE SECOND
E15 (O2 sensor ground). This isn't the problem.
Ignition Signals:
D8 (engine rpm) As stated above, the vehicle is running. This won't be the issue, but I am betting a meter on DC will show about 1.5V at idle assuming a 70% duty cycle
C7 (ignition bypass-brown/black wire). Talked about above. This is a SYMPTOM of the real problem. Around 5v (my test vehicle is 4.66V) once the vehicle is running.
C8 (EST-white wire) Should be seeing (my guess based on the likely dwell (assuming 70% dwell for idle) would be about 1.5V with my rough math).
If this was a vehicle I had to diagnose for no spark advance, I would look have looked at the ignition signals first, then the powers (fewer and easy) and then the grounds. I would use a power probe to put a momentary 20A to the ground circuit and make sure it can pop the circuit breaker, which would indicate a robust ground).
The power probe III can be purchased many places but here for sure: http://www.aeswave.com/Products/Product.asp?i=856&mi=50
For Reference:
Engine cranks- Reference voltage (AC voltages-sign wave I would guess around 1.5V AC) is observed by the ignition module. The module sends the signal (at this point a square wave DC voltage averaging ~1.5V DC at idle) to the PCM which uses it to not only determine injector firing times, control idle speed and even keep the fuel pump running. Since the vehicle is running okay, I would suspect that the pick-up and the D8 engine speed wiring is okay.As soon as the module sees 400 rpm(sh) the module releases the 5V EST signal (white wire-square wave as digg explained) and the computer takes over spark timing. If you pull the white wire only out of the circuit, you should see a 5V square wave (meter would read somewhere around 1.5V (ish) DC. If the Voltage isn't there, then the PCM isn't working correctly (on the EST circuit side).
I plan on scoping this out tomorrow to verify what is just rough math for voltages. I think, if I'm right or I correct these values to be correct, it would make for easy testing of the ignition system.
Good night. Good luck.
ghettosled
SYTY SUPERSTORE
well i think we figured it out.. customer or someone outside of our shop apparently took the white reference wire and plugged it back into the ecm in the wrong pin location. Must have come loose when they were tinkering with something under the dash. Kinda ironic how things like this just "all of a sudden happen without touching anything" umm yeh.
big thanks to everyone who has helped.. The_Bronze i owe you something.. let me know when you need some parts.
