primemover
My Ty just upped and developed a problem. My battery is bone dead after it sits over night. I know my charging system is working because it charges at over 14 volts. I checked this with a meter. Also I disconnected the negative terminal of the battery when it had a good charge on it, let it set over night, and reconnected it in the morning and it was able to start no problems.
So that means it's a load happening that's not supposed to happen. I know its not the air shocks pump because I took that fuse out a long time ago due to the pump running all the time.
I can't see that any lights are on when the doors are closed etc.
other then randomly pulling a fuse and checking it every day to isolate the curcuit is there anything I can do to track this down faster? Maybe this is a problem with ty's and it's usually something I can check first? Thanks in advance.
