enigne question
syclone2910
I have just got my new motor back and i was needing to know if i could run it with the stock chip or the pitbull chip that i have. I have a 412 cam, L35;s with 202 160 that are maxed out on the proting and a t44 turbo. I have 50 lbs injectors and the stock one also. I have a chip ordered from brian, but the new chip has not been finshied yet. Sp my question is can i run the setup that i have with the stock injectors? And will it run right?
smeagol
You have a lot of airflow, which is why you need the 50s, if you boost it, you'll go lean => kaboom.
You *should* be able to start it & drive it with the stock injectors & pitbull chip, but I wouldn't start really getting into it.
If the chip is THE only thing you are waiting on, let's reprogram a memcal with a program for the 50s & 3 bar to get you going until the new hardware is here.
