Fabricated a throttle body adapter today !
vortecfiero
this is only a mock up... my welding sucks.. to see if the shapes etc work
I will repeat the process in stainless and have it properly welded
click on the thumbnails to see the full size pic
and yes I still have an hour or so with the die grinder to finish it
NecroWolf
lost marbles member
Re: Fabricated a throttle body adapter today !
if you weren't so wild with the grinder and used sandpaper from 80-220 it would have slicked up pretty good but it still looks like an idea but will it flow enough? every thought about just using oval pipe and then get a round to oval adapter to do the same thing?
vortecfiero
lol I had to grind alot because my welding was so lumpy
all the formulas I've used or charts* ive seen show that using 2.5" tube on the intake system will support over 400 hp
2.00" - 255 hp
2.25" - 345 hp
2.50" - 450 hp
2.75" - 565 hp
3.00" - 690 hp
3.50" - 970 hp
these are based on maintaining the optimum flow rate. Of course bends and tube
size changes in a system will slow things down
*Page 155 - Forced Induction Performance Tuning - A.Graham Bell
IBSN 1 85950 691 1
I want to avoid too many off the shelf adapters in this setup I'm hopeing to have a "one off" look and dont mind the challenge of designing the parts and making or haveing them made
MikeRenz
not stock
i'd put a bead around the lip of that to help prevent it from blowing off the tb
vortecfiero
here is another one... jeez im actually enjoying this stuff
George Blake
DONATING MEMBER
So you'll make me one for free? ;) J/K.
I think they look good. Have you thought about making an adaptor on the back side to adapt a syty/corvette throttle body to the Edelbrock 2114 manifold for use with Vortec Heads?
