Fitting for turbo supply line on block
fastsuv
Does anyone know what type of fitting is on the block for the turbo supply line. I had my engine rebuilt and didn't get the fitting back. Any help would be appreciated.
Kevin
93ty475
do you still have the supply line? see if it has the same female end on both ends of it...if so, then just unscrew the male fitting off the top of the turbo and go find a match...should be the same if its anything like mine....turbo feed is on the driver's side of the block...1/4 or maybe 3/8 inch pipe threads if i remember correctly...buy a brass tee with three females, plug up one and use the other for the turbo feed...you'll have a spare port for a mechanical oil gauge later...
ghettosled
SYTY SUPERSTORE
the test nipple is 4an.. The hose ends on the turbo feed line are -4, and the hose is -3. I wanna say the hole in the block is 1/4" npt but i'm probably wrong. :drinking:
