Davemc1963
93 Ty Owner
A bit long, but I just wanted to add to the following post, which is now a Sticky.
http://www.syty.net/forums/showthread.php?t=75060
I wish this was posted a couple of weeks ago, it would probably have saved me hours.
It must be Fix ABS week, because I have been looking at mine for the last few weeks as well.
I also found the post below useful, covers similar things:-
http://www.syty.net/forums/showthread.php?t=61960&highlight=abs
Thanks go to DaveP for the bulk of the help and knowledge on this subjectwith respect to SyTys!
My ABS came on about a year ago, following a bit of work I carried out on the Ty.
I posted a few questions, and was pointed to the Brake light switch as I also had a syptom with the TCC 'not feeling right' However, the switch was correct, so this was not the solution for me.
Now this last year, I just haven't had the time or opportunity to do any work on the Ty, I have just had to drive it (albeit infrequently).
However, I decided it was time to do something, as it is time for our Annual MOT. (roadworthyness test) and the ABS is part of it. Last resort was removing the warning light bulbs!
To cut a long story short, after a lot of 'Searching' I decided to make a start at diagnosing the problem.
Thought it was 'White mans magic' teritory (no offence meant to anyone)
Like most things, it was a 'Back To Basics' solution, No Power = No Work
Turned out to also be the 12v feed near to the battery that feeds the BPMV or ABS unit. It had a break in it. It looks like at some time, it had been rubbing on the battery tray. This, also has a fusible link in it, but for some reason this was OK. I managed to splice it back together after cutting out the damaged bit.
I then tried to clear the codes I had got to 10 and stopped counting!
However, this took a few attempts and ignition switch cycles. ( Ignition on, Short terminals A&H for 2 seconds, Off for 1 second, Short again for 2 seconds. After the first attempt and thinking I had further problems because the codes were still there, I persevered and they all cleared, i needed to cycle the ignition switch again, not just the A to H short. then, just code 14, which as DaveP has noted is a normal code for the ABS - Yeh.
I had also looked at bleeding the ABS, seems to be a bit of mystery in this and I have been unable to ascertain if there are any risks to this. The factory manual is a little vague in this.
some info here;_
http://findarticles.com/p/articles/mi_qa3828/is_199806/ai_n8787970/pg_4/
and they have been referenced by DaveP previously as well.
I would like to do this as preventative maintenance, but now its working again feel a bit reluctant, in case it breaks again.
A tool (2 off) to open the accumulators is identified one outlet of many is:-
http://www.sjdiscounttools.com/otc7853.html
As for bleeding, found this, but not specific to us:-
http://www.cardone.com/English/Club...KES/Protech/Install_Instructions/93058412.asp
Also, I have come across several references to NOT vacuum bleed the ABS unit - haven't found out why though??
Bleeding the ABS is in my future though, cant be good to have old fluid in there.
I also had it in my mind that I may have to pull the unit apart and check out relays etc. Not a lot of info around for this, but it turns out the units aren't rocket science. the link below looks at a Kelsy-hayes unit on a Fiat. Not ours, but gives an insight to whats inside these units if your is dead.
http://www.fiatforum.com/bravo-brava-marea-guides/94836-how-repair-abs-central-unit.html
Just sharing what I found, Thanks to DaveP and the community.
some info here;_
