Front Brake - LS1 uprade how to
Daron
Has anyone done a step by step how to? I see the rear swap instructions MadGumby has going on and am lookin for the same for the front... Yup I searched.
Re: Front Brake - LS1 uprade how to
I have done it it pretty easy all u have 2 do is to get your spindle and cut the ears of it there is a company that sell the kit it come with a booklet explaining how 2 do it . I believe that they (advrtice) THEM SELF IN the forum.
NJ93TY
I have the instructions somewhere, if I can find them I can E-mail them to you. Its pretty straight foward.
Aeroking
e.i.
i remember reading something about LS1 brakes, and Cuisinart wheels... let me know how it works out :tup:
s_blazin
i just put mine back together today, had to repack the bearings. you know you can only buy the whole hub assembly, you can't just replace the seals? no one offers them at all. and new hubs are 150ish new from napa. so i just cleaned mine repacked them and pressed them back together.
but anyways it is really easy to do, just need a grinder and some time to cut the stock caliper mouting points off of the spindles, find a conversion bracket, bolt it all together and reassemble on the truck. of course you'll have to get new brakelines but they are super easy to build if you get lines and fittings, then you can cut to fit perfectly.
very very easy
Daron
very very easy
I just bought the seals today from Advance Auto and put them in. Ive got the conversion bracket. Just need the bolts to secure to the caliper to the conversion brackets.
