front coil over suspension
elorejas
is rpm the only dealers of tubular control arms and coil overs or who sells coilovers for stock suspension to get rid of the torsion bars
epix
Typhoon
Re: front coil over suspension
TurboTime does, not listed on site email them. There may be another vendor coming out with these shortly as well.
elorejas
thanks restoring a syclone and want to install coilover all around but $1,600 is to much right know just want to install coilovers and down the road add the tubular control arms
Smkur50
SYTY Fleet owner
How much is just the front coilover setup without the tubular arms? Also what is the weight savings for just the tubular arms vs stock arms not including the torsion bar removal?
GarnetTy1473
From what I've heard, E-Rue isn't building/making any parts syty related any more. He's making a bunch of money doing Subaru stuff, so that's his focus now.
TY162
I just emailed TurboTime last week about coilovers for my Ty. Single spring front $689/pair. Dual spring front $779. Rear $585. All plus shipping. They won't give you any spec.s. You give them your info- weight,useage etc. Then they'll build them.
TY162
Do you know who the other vender is? I'm still looking for a front set.
BoostedSUV
check out the thread about stock a-arm coilovers. There's everything you need to piece together your own "kit" and use the stock a-arms. You can probably do it for $4-500. I haven't priced it out yet but I'm looking into it.
TY162
Quote:
Originally Posted by epix
Been researching for a few months now and for those wanting to DIY I believe these are the parts you'll need:
Front
Shock - QA1 DR4855P aka DS402 (thanks PPI Typhoon!)
Springs - Hypercoil 9A0600 (2.25" diameter 8" spring), need 1" spacer
Spacer - GEN-GC1032
Spring Cups - Custom machined
Bearing Kit - COM8T-102PK
Bushing Set - 9.8140R (Wear out quickly??)
Rear (non coilover)
Shocks (lowered) - QA1 1915P
T-Bar Adapter - BAR350K
Eyelet Mount Adapter - SS300LT
Lower Shock Bolt Kit - QA1 7888-108
Here's a cut and paste from the other thread.
