Front dif install & removal made easy
Don W.
After fighting a front dif three times since owning my Sy I tried something different. I had removed the oil cooler lines to make it easy to R&R the pan and the adapter to check for a possible leak and decided to leave them off to see if it would make the dif install any easier. What a difference. With those parts removed you can jack the front dif up past that rear support far enough to rotate the front support right into position. No twisting, no turning, no swearing and not a scratch on the pan. With the wife helping on the jack (I just ain't strong enough) we had that sucker in there in just a few minutes.
Note: I did have the tie-rod out so I can't tell if this works with it in or not.
I know it's a bit more work to remove those parts but next time I won't even think about it. Those parts are coming out first.
Hope this helps the next guy. I couldn't believe how easy it went.
Try Me
Re: Front dif install made easy
Yea if you have the drag link out that makes a huge difference. (i assume thats what you meant by tie rod)
Don W.
Heh heh, ya that's what I meant. I think it takes both to complete the assembly from side to side. Never quite sure which is which but a quick internet search revealed both terms. Drag link in the middle and two tie-rods, one each side.
To me the drag link goes from the gear (mounted on the frame either in front or behind a beam type axle) to the left spindle and the tie-rod goes from left spindle to the right. Darn semantics anyway...:roll:
Osmosis
Don,
It would be great to get a pic by pic installation thread link on this topic as I know it is a PITA:lol:
DMTY
Wish I would have known this in May. Did mine on a hoist and didn't have a tranny jack to put it in, Took a buddie and I about 45 min to get it maneuvered in there just right. Felt like my arms were going to fall off when we were done.
Don W.
Ya we live and learn I guess. I would have stuck up some pics but there's really not much to take a pic of. With the adapter and lines removed it just goes in. I am gonna change the title to add "removal" so people will find it easier.
s_blazin
Re: Front dif install & removal made easy
i ws fighting mine yesterday, about a half hour ago i pulled the lower drivers control arm off, the front diff flew into place so fast it made my head spin LOL
