Front stabilizer shock
blackty
Do we need them? Mine does not have one. It has the one mount for the shock but the center link does not have a hole to put the other end in. Is it possible someone changed the center link and put the wrong one in or didn't our trucks require them? Jim
jwaller
Evil Genius/SyTy Guru
they are all like that.....if you find an older s-series they will have a hole in the center link. all the 4x4 frames have the mount. they deleted the centerink mount when it was discovered that the steering stab was worthless.
Rick Krupa
"they deleted the centerink mount when it was discovered that the steering stab was worthless."
Just like THEY probably referring to GM deleted the rear Sway Bar which doesn't do anything for the Sy/Ty. Humm yah right!
I have the front steering stabilizer shock and the ES rear stabilizer bar and like both.
Lynn D. Brown
Steering Stab.
Steering Stab.
I have both the Rear bar and the Stabilizer and also like both, and they definitely helped stability and handling. My Centerlink - a GM dealer replacement - has a hole in it for the shock tapered rod - yours doesn't ?
I think the Frt Stab shock will do alot of good to lessen shocks and wear on the rest of the steering linkage. And it should remove alot of the Slop from the POS factory linkage if U stiil have it.
Lynn D. Brown
Steering Stab.
Steering Stab.
I have both the Rear bar and the Stabilizer and also like both, and they definitely helped stability and handling. My Centerlink - a GM dealer replacement - has a hole in it for the shock tapered rod - yours doesn't ? I wonder if GM stocks Centerlinks w & w/o this hole ? This hole, combined w the bracket on the frame to mount the other end of the shock make the installation of a Frt Stab kit (I used the Rancho kit) nice and straightforward. I was shocked - how often does this happen ? Most of the Mods I try end up in a big F-ing quagmire !.
I think the Frt Stab shock will do alot of good to lessen shocks and wear on the rest of the steering linkage. And it should remove alot of the Slop from the POS factory linkage if U still have it.
blackty
Nope, no hole in the center link. Next question then, will any S-10/S-15 4 X 4 center link be correct? Jim
Lynn D. Brown
Jim,
I think I looked at one that Napa had that had the Stab hole. I would just go to a couple of stores and have them pull the part. Maybe they could pull one w & w/o the hole and match up the parts ?
I'm pretty sure that U can get one 4 the SyTy's w the hole in it. I don't suppose U have the old one out to compare to ?
i believe the moog replacement does not have the hole.
mine does not, unfortunately, either.
bu i dont think its worth changin out for my circumstances.
blackty
No, old one still in, daily driver. REALLY sucks when I hit a groove in the road and the damn wheel nearly gets ripped out of my hands. A modification for the near future. Thanks. Jim
BillC
Rancho makes a bracket that clamps to the center link for installing their steering damper. I've had it on my Ty for at least six years (along with their damper), and never had a problem. Unfortunately, I don't remember the bracket's part number, it was part of an installation bracket kit. I think I might still have the box at home. If anyone's interested, I can try to dig it out and get the kit part number from that.
Lynn D. Brown
Front Stab
Front Stab
Bill,
I don't remember whether my Rancho kit came w a clamp 4 the Centerlinks w/o holes - since my CL had the hole and the tapered link to go in the hole.
So, did your kit come w both the link and the clamp, or did U have to order the clamp after the fact ?
Rick Krupa
Just look under our site under the Sy/Ty section Rancho Stabilizer and you'll see the bracket installation kit which comes with the Rancho we sell.
Later,
blackty
Bill & Rick, thanks for the info. Hope the weather is nice this weekend. Since there is no hole in the centerlink do you have to turn the wheels in any certain direction to get even amount of piston travel? Jim
Rick Krupa
Jim,
I'm looking at the bracket installation kit instuctions right now and it is detailed with photos on where to place the bracket. It took me around 20-30 minutes to install some years ago.
Later,
