Hey guys , before I put these up on ebay I wanted to make a thread here. Maybe you or a mechanic you know might need these. I came across these when a GM retail dealer here in san diego closed down and liquidated all their assets.
Here is a list of the Items I have for sale :
Kent-Moore J-42598-B Name:VEHICLE DATA RECORDER
Kent-Moore EN-47836 PISTON RING COMPRESSOR
Kent-Moore J-44757:TRANSFER CASE SHIM SELECTOR
Kent-Moore J-44721
ower Steering Analyzer Applications:H1&H2
Kent-Moore J-45681 Jumper Harness
Kent-Moore J-24642:H.E.I. ADAPTER
Kent-Moore J-24086PISTON PIN SERVICE SET
Kent-Moore J-45405:Brake Pipe Flaring tool Applications:All GM Vehicles
Kent-Moore J-25019 BUSHING SERVICE SET Applications:325 200 THM
Kent-Moore J-41425 :A/C LINE REPAIR KIT LOKRING
.Kent-Moore J-33373 :SHIM SELECTOR Applications:M200
Kent-Moore J-42094WHEEL HUB BEARING R & I Applications:GTO To remove and install the wheel hub bearing.
Kent-Moore J-34925 PINION SETTING GAUGE SET
Kent-Moore J-47800 Shim Selection Gage
Kent-Moore EN-48260 PISTON RING COMPRESSOR
Kent-Moore J-39700 ( X 2 ) :UNIVERSAL BREAKOUT BOX 180
Kent-Moore EL-48458 Precharge Tester Applications:2-Mode Hybrid Trucks/SUV’s
Kent-Moore J-42958 :CRUISE CONTROL TESTER Applications:H2
Kent-Moore J-44757 TRANSFER CASE SHIM SELECTOR
Kent-Moore J-46664 Pump Alignment Tool
Kent-Moore J-38621
Kent-Moore J-38792 Electronic Vibration Analyzer 2
Kent-Moore J-43690 Rod Bearing Checking Tool
Kent-Moore EN-46999 DOD Tester
Kent-Moore EN-48260
ISTON RING
Kent-Moore J-38715 SIR LOAD DEVICE.
Kent-Moore J-35667 LEAKDOWN TESTER
Kent-Moore J-37808 COLUMN LOAD TOOL
Kent-Moore J-26935
Kent-Moore J-38716 TEVES ABS PINOUT
Kent-Moore J-46010 =6.6 Diesel Kit , 250 on ebay complete
Kent-Moore J-45709 LIMITED SLIP DIFFERENTIAL KIT
Kent-Moore J-29803
Kent-Moore J-36660:TORQUE / ANGLE METER
Kent-Moore BT-7707UNIVERSAL GAUGE TESTER Applications:J 24538-B
Kent-Moore J-45692 SHIM SELECTOR
Kent-Moore J-44900
Kent-Moore J-33431 INSTRUMENT PANEL TESTER
Kent-Moore J-44295
Kent Moore DT-48218 X2T Magna Transfer Case Tools
Kent-Moore J-41540 HOMELINK TESTER
Kent-Moore J-34196 TRANS BUSHING SERVICE SET
Kent-Moore J-39303 CELL CELLULAR PHONE TOOL KIT
Kent-Moore J-44388 FINAL DRIVE END CHECKING
Kent-Moore J-44721
Kent-Moore J-38621
Kent-Moore EN-48260
Kent-Moore J-26935
Kent-Moore J-29803
Kent-Moore J-44900
Kent-Moore J-44295
