FYI for smokey start ups
turbonut
thanks to all the guys and gals of this forum. i replaced all the valve stem seals on my 93 typhoon with 63,000 miles. the exhaust only had o-rings but the intake had the umbrella seals and o-rings. they were so brittle that some broke when i removed them. no i don't get any smoke on start ups...what a relief. the guides had some wear but not enough to pull the heads. the parts were a premium seal from the local auto store, cost about $40 cdn. i highly recommend the fix.
SY756
Re: FYI for smokey start ups
Which method did you use to hold the valves up in place? I have heard of different ways. I assume you didn't take off the heads. . Just curious how you did it and how it worked out for you. May replace mine sometime soon.
Bill Z
SY756,
I don’t know how Turbonut did it, but I use a cotton rope and shove it into the spark plug hole. Then turn the engine by hand until the piston is at the top. I then use a spring tool to remove the spring keepers and spring.
I tried using the compressed air in the spark plug hole but frequently, the keepers would be so hard to break loose that the valve would go down letting the air loose. Plus the air would shove the piston down and I ran the risk of dropping a valve in the cylinder.
Hope this helps.
Good luck.
SY756
Thanks Bill. The rope method was what I had in mind.. I was worried about using air.
turbonut
i used compressed air to hold my valves, just find TDC for that cylinder and use your shop air to hold the valves, i've heard of the rope trick but be careful of any left over debris from the rope. i'd use a nylon rope but make sure you use a flame to slightly melt the end so no fibres get left behind. good luck, it's a 4 hr job without taking off the heads. the tool was about 20 bucks, worth the weight in gold. good luck.it's common to find that the exhaust side only has o- rings and not the proper umbrella seals.
syclomatic
Syclone #2481
Wow sounds like a good project for me. I will most likely ask bunches of questions when I start, so beware.
