too many toys
IM LOVIN IT
i was installing it and went to pull the connector for the controller apart and the wires on the hookup side pulled right out , there is only 2 wires in this connector so i can probobly just cut the other side off and put a new connector on it but i dont know which wires go to each other if someone has this controller and could let me know that would be F-N great its a greddy profec E-01 the wires on the controller side are pink/black the wires on the hookup side are green/white
second ? what wire do you hookup to for the rpm signal, can i tap into the white wire off the coil
