Help--Old front tires very worn on inside??
JohnC
I've been told it was the camber?
What are the stock alignment specs or camber specs?
I guess they are the same thing?
Thanks JohnC
MikeRenz
not stock
have you lowered your truck? between your harsh ride thread and this....i'm guessing you have 2-3" lowering blocks, and your torsion bars cranked down low. Doing both of these will make for a harsher ride and if you fail to get an alignment done in the front, you will wear out the insides of your tires.
