How much knock is too much?
Aktyguy
What's everybody's opinion on knock retard? I'm at 20 lbs of boost on the T72 and the o2 mv's are about 900-930. Getting about 10-11 degrees constantly. I'm using 110 octane fuel.
phoonTy
Truckless. For now.
i'm no expert, but 10-11 degrees constant is way way too much. i assume you're running it on DM? if it's 10-11 degrees for more than a few frames, then you'd better check some things out quick, and lay off boost for a while.
0 degrees is optimum, but with these trucks, that's sometimes hard to attain. from what i've read, and talked with people about, the occasional 3-4 degrees is acceptable, but as always, the lower the better.
although, using 110, it may be false knock. but i'm sure someone here will chime in with some good ol' "know how."
Jimmy
Banned
You are about to blow your motor up.(or it could be just too rich/lean)
12.something is max,and I think most ppl agree that anything under 5 is not too harmful.Don't beat on it with that much KR,do a complete tuneup,make sure the timing is at 0 degrees,and that your IC pump is working.
phoonTy
Truckless. For now.
I believe 12.7 is max. we tested some MHST trucks the other day, and a few maxed out T-Link to 12.7 with KR. We got one back in tune real quick, the other truck needs more stuff done to it first. so yours could be something simple too.
E-Rue
anything less than 2 deg is acceptable on a stock truck, but i normally shoot for 0 on my sy with the built motor. its been pretty easy to keep 0 in the sy, but ive always had a really hard time getting 0 in a stock truck.
e
spooldup
Super Member
just wondering. Can you guys hears the knock on your trucks? My truck is silent but as you adjust fp the kr changes so i asume it's real.
Sy769
12.7 is max on Stock chip. Hopefully you are not on a stock chip. Kind of depends on how much timing is in the chip. If you did a chip with 25 deg. of timing advance then 10-11 of retard wouldn't be bad. If your distributor isn't really at 0 then the engine is seeing more or less timing than in the calibration. If you have a stock truck that retards 2 deg consistently and you advance the distributor 5 degrees then you would probably see ~7 degrees of retard.
So it sort of depends on how much total timing the truck is actually seeing.
Have to look at the whole picture.
InvisiBill
"Knock retard" is when the ECM retards the timing to stop knock. If you can hear it, then there's more knock than the ECM can cancel out via timing retard. That's bad.
Sy769
Keep your foot in it when you can hear it and you are the retard. As long as the timing reduction stops the detonation you usually aren't hurting anything although performance suffers, which is why we want 0.
Aktyguy
I think the cause of the knock was a problem with the cam bearings. The rear one spun and was moved forward blocking the oil passage to the lifters and the top end....pretty sure that was it.
I'm running 20 degrees of advance with the distributer at 0. I've been testing it on 28 lbs of boost and i'm sure the knock isn't real. It's too intermittent, even in the shop at just over 4000 rpm it'll pull 10 degrees for no reason. I retarded the timing via the distributer about 4 degrees and it doesn't change anything.
I changed the crank and bearings a couple weeks ago and pulled it apart today to check the bearings again and noticed the cam bearing problem.
100in6
100in6
assume from your last post you've already taken it apart. for what it's worth I have never heard a ping out of mine ever. either one. you've got too much. what kind and how big of an IC are you running? As boost goes up so does heat and heat is one of the things that will raise the knock, especially at the end of the run when the IC starts to get hot. where in the run is it knockin?
Aktyguy
How much timing are you running at full boost? How much boost and what kind of fuel?
My intercooler is pretty big. It's a spearco core about 30" x 16" x 3". My IAT is about 80-100 degrees. No more than 100 degrees after a full run. Engine temp is about 167F.
The knock I'm seeing is right on the launch, it'll count up a few but then that's it. I've made some passes on the highway at 28 lbs of boost with 0 knock. I'm not hearing any knock, only seeing it from the knock sensor.
The problem with that spun cam bearing is that supplies oil to the lifters, with no oil they start to collapse and I'm loosing a bunch of valve lift at that point.
Aktyguy
Ya well the air temp was only 60 degrees so that might have somthing to do with it :)
How much boost are you running?
