I think I found the problem!
berzerker
wookie
Re: I think I found the problem!
i've got a slightly used magnaflow muffler you can have it for $ 20 . i would pull tha cat off and install a test pipe in place or gut the old one and just run a muffler . do not ! i repeat do not put on a god damn flowmaster muffler or you'll just go backwards performance wise !
Epstyphoon303
1992 Typhoon #2019
Hell no I would never run a blow-master. Ill let you know on that magnaflow.. So according to the list of things I have changed can anybody suggest where I may have gone wrong, Or should double check?? I plan to adjust my waste gate tomorrow morning and check my timing, plugs.
Why don't you just drive the thing down here this weekend and I'll help you fix it with in an hour or two.
BoostedSUV
I would start by checking wastegate rod adjustment, second I would check the wastegate spring pressure. Try to open the wastegate flapper by hand, you shouldn't be able to without a considerable amount of force. Third I would checl spark plug gap. I've never seen a vehicle where gap makes so much difference. 035 is probably Ok but I like running them tighter, 028-030. Those would be my suggestions based on where your hands have been. Most problems with these trucks are caused by the one working and making changes on them... Ask me how I know. Lol
I am with the above 2 posters. I would make sure the truck makes base boost 8-9 psi (solenoid disconnected or bypassed) and then trouble shoot from there. Blindly Throwing parts or removing them is not the best way to fix a problem.
