After reading numberous posts about how to set the IAC, things just aren't working for me.
I have had this issue all year nad it just won't go away. Maybe some of you more experienced TUNER GUYS will have suggestions that I could check in TunerPro.
When I start my truck, I usually see rpm's at 1700 or so, not good but if I let it sit and idle for a minute or two it will work it's way down to normal around 800. Turn the truck off and start it up (after driving a distanec) and I see 1700 again. Just today while I was driving it, I noticed that instead of eventually going down, the rpm's increased. By the time I got where I was going the idle was 2300.
I pulled the iac, adjusted it in by hand and made sure it was clean and the spring positioned correctly. Fire it up and it adjusted itself to a normal idle from very low. This tells me that it is working but there may be some issues elsewhere, possibly in the tune I have loaded? Next time starting the truck, I see higher than normal idle again.
Any suggestions on what may be causing this? I don't have any vacuum leaks that I know of and the vac/boost gauge seems to act normal within typical ranges.
