GAShan
What is the minimum I can remove to get to and replace the IAC on the throttle body? Leon's IAC on his Typhoon is frozen and won't allow the truck to idle below 1500 RPM. When I did mine I pulled the heat exchanger and throttle body but his has hard lines so that is a pain. Any tricks?
