blazinmt
First off, I am not a mechanic and lack some experience when it comes to working on vehicles. My questions may seem trivial to you veteran SyTy owners, but please bear with me and help me out.
I have an IC pump leak (well one of the lines going to the IC pump to be exact) and would like to know the easiest way to access the IC pump to fix this. The line that is leaking is behind the pump (if you are on your back looking at it) and the pump seems to be tucked quite nicely up over the sway bar just out of reach. (SEE PIC)
I also have a small oil leak coming from what I believe is an oil return line from the turbo. There is a 90 degree fitting coming out of the oil pan that looks to be the cause. Can I just remove the fitting/line and replace/retighten? Or is that line going to dump a bunch of oil all over the place if I unhook it? The line should be empty if it has been sitting right? (SEE PIC)
Advice wanted and appreciated! I would like to start turning the wrench on my own vehicles and I might as well start small!
Thanks Robert
Thanks Robert
