Idle pulley location
TDSRacing
The idle pulley and the one on the belt tension. On the TY which one gets the larger, of the two, pulleys? To get the pulleys to line up I had to put the bigger one on the tension arm but that puts the belt CLOSE to the water pump.
gjp
another post whore
Re: Idle pulley location
on my sy the larger one is on top.
socalblue
The pulley on the tensioner is bigger...hijacking the topic here but anyone run a A/C bypass pulley? I just put one on and now I noticed that the belt doesn't even touch the smaller idler pulley now?
TDSRacing
Mine is from Summit and does touch and go around the small idler.
while on the subject......i have been working on a bracket setup that will eliminate the big ass accy brackets that hold all of our accy's...ie ps,alt,ac cond...
i need some help...looking @ the front of the engine which way does each individual item spin. in ref to clockwise or counter c-wise.
