Ignition Switch Stuck
tbauer03
TRBOBOX
I got a new Typhoon the other day and the ignition switch is stuck in the run position. It turns forward to bump the motor but when I turn it back to shut it off it feel like it is hitting a brick wall. Therefore I can't shut down the truck or remove the key. I got a chilton's book that describes the how to replace it but I was just looking for tips or tricks from others who have encountered this problem thanks.
-Ted
fauXGT
Brick Pilot
Re: Ignition Switch Stuck
Wiggling up & down the ignition lock lever as you turn back the key doesn't release it?
wheels
I had this happen once in a Blazer many years ago. A new tumbler was in order. I remember vaguely that I needed some sort of steering wheel puller. I'm not that much help really, am I?
fauXGT
Brick Pilot
Yes, if a new ignition is needed, a GM steering wheel compressor is needed ( get at Schucks $15) & a steering wheel puller( also @ Scmucks). & a small torx (which size I can't remember), to remove ignition screw inside.
powercat6
-Ted
Did you buy the white 93 in KCMO?
s10blaza
BOOSTED
Steering wheel puller at any parts store. (the $6 Grant one works fine) You can rent a lock plate remover from them as well.
Pull the steering wheel, lock plate, remove three screws holding the turn signal cam assembly and pull it out of the way. Use a small torx (T-15) I believe to remove the pin holding the tumbler in and it will slide right out. I can get one done in less than 30 minutes start to finish now.
Don W.
Prolly the tumbler but what has the trans interlock have to do with this?
Turboz
NASTE
There is also a cable that goes from the column to the shifter if for some reason it has come off the shifter the key will not go back either had this happen to me. You can see it if you take off the cup holder portion off the console. Also you can remove the lock plate alone, installation might require a buddy as I did but no special tool, even though they do make one.
Jay
-Ted
keith455
Average Joe
Staff member
whatever you do don't try and force it to turn with a wrench, don't ask. I had one go out on a blazer and i got it to work for a little while by spraying tons of WD40 in there.. but ultimately I had to replace the lock.
ARIZONA QWKSTRM
I just went through this same thing. I went to Autozone and borrowed the steering wheel puller and lock remover. It was an easy job with all the correct tools. I like the tool borrow so all I had to buy was the tumbler, cheap fix. Good Luck!
