INTERCOOL PUMP for 93' Typhoon
CHEVYSS
Does anyone know how to check if the intercool pump is good or bad on a 93' typhoon?
Also, does anyone recommend a after market chip for stock applications?
NorwegianTy
Re: INTERCOOL PUMP for 93' Typhoon
The pump is controlled by a relay on the fire wall.
Two relays, the fuel pump (I think)and the IC pump relay are placed together.The right one of the two is for the IC pump. The one with a yellow wire.
Take the yellow wire and connect it with ground, I dont remember if you need to turn the ignition on or not, but just try and you should be able to hear the pump running.. You hear it pretty well when the trucks not running..
Another hint is to use the search function on this forum, and you will probebly find a lot of information on how to do this...
SY2932
Administrator
Check out my post here how to check it. Don't forget to check to make sure that the fuse isn't blown if it doesn't work...
"Intercooler pump fuse location behind alternator. Fuse is in a weather pack connector and the top has to be opened to expose the fuse."
CHEVYSS
thank you all youve been very helpful! i still need to know if anyone recommend a after market chip for stock applications?
