intercooler hose keeps blowing off under boost
syclone74
My intercooler hose keeps coming off under boost, any suggestions? Also I installed a new cam ( comp cams 510 lift) and vortec heads ported and polished with 205 & 160 valves. What should my timing be. Need some help.
MikeRenz
not stock
Re: intercooler hose keeps blowing off under boost
stock intercooler? if so, do you have the middle intercooler support brace installed?
T-Bone
Tighten the hose clamp.....
typhoontaz
clamps and timing
clamps and timing
Worm screw clamps suck, use the better, more reliable, more expensive, t-bolt clamps. I would set the timing at 0 degrees with the EST wire unplugged. The wire is located on the passenger side compartment, right on the firewall near where the passenger's feet would rest.
qbnkiller
Conflaguration Specialist
all the above is true. Another trick is using hair spray on the metal pipes. Funny as it may sound, it works pretty damn well!
