It wont quit bottoming out
BPATT
I lowered my ty 3" it bottomed out on the passenger side. Then I changed it to 2 still the same thing. I went and bought KYB shocks still the same thing. I bought a sway bar but I haven't put it on yet. Will koni's stop this or should I be looking for springs? Thanks BP
4C FED
Absolutum Dominium
With 2" drop blocks on my Sy, it would bottom out. I took them off.
After looking at other trucks it appears that my springs have sagged.
I measured something like 23" from the ground to the peak of the wheel arch without the blocks.
Try replacing your springs if you are set on lowering it or look for a spring that has a higher spring rate. Or you could cut the spring snubbers down, maybe in half, and see if gives the extra room needed.
A swaybar won't help your bottoming problem.
