Keyless entry
Lamotta81
Are all the typhoons equipped with keyless entry or what??? I just purchased a keyless remote on ebay and hopefully it will work with my truck. Where is the module for the keylessentry as well any information would be appreciated
Re: Keyless entry
The module is under the center console in the back. I am going to attempt to reprogram my remote soon. I am pretty sure the intstruction can be found searching the mailing list archives on www.syty.org
Jimmy
Banned
1.Get a piece of wire.Leave ignition switch off.
2. Connect ALDL terminal A (upper right) with Terminal G (lower left). Door locks will lock and unlock in approximately 2 seconds.
3. Press "UNLOCK" button on remote. Door locks will lock and
unlock in approximately 2 seconds. The remote has now been programed.
4. Disconnect the jumper wire from the ALDL.
tbauer03
TRBOBOX
Hey i just got a new remote and was trying to do this and when i connected the A and G terminals nothing happend i played with it for awhile and couldn't get it to cycle the locks. Could i be doing something wrong?
TY#1071
Same thing here - nothing happened when I coonected A & G. Anyone else have this issue or better yet what could be causing it? :(
Thanks,
ShuggsRR
Re: Keyless entry
Pull the center console out and its under it? Hmm...
I have the lid off now and can see back behind there in a box there with wires. dang gotta take the truck apart some more! lol
Ok pulled it out. Everything is plugged in. My Typhoon service manual says "see Jimmy manual" but I left that at the shop. Poop. Guess I have to go get that manual before I put my console back together.
