Kill question
phoonerorlater
I just bought my 1993 Ty. It has a 10-1 chip in it and i believe it has a shift kit. I have been challenged by a new mustang GT. should I have any problems? I will set the boost to about 17.5 psi I think. Any suggestions?
Ty#1893
Keith
Ty0279
Historically Significant
Re: Kill question
Shouldn't have any problems with the GT. It'd be a good idea to get a scan tool on your truck before you run higher than stock boost levels...better to be safe than sorry.
Falco
Re: Kill question
I second that. Learn your truck first and accept chalenges second.
Peace,
TunG
unless ur truck is running real shitty, u should rape him like none other. they are not even close. when my ty was stock i raped a S281 saleen. the problem with the stangs is they cant put the power to the ground unless they got mad rubber and suspension setup for dragracin.
SY_1306
gt
gt
a buddy of mine has a new 02 mustang gt. we raced from a 35 mph roll and i wasted him. Had about 2 car lengths by 65
les
agree on that scan tool stuff. Do you have an adjustable fuel pressure guage yet? RK Kustom sells a good one. you can get it other plaaces too. biggest thing in tuning these things is fuel pressure and detonation. If you don't have datamaster or diacom, start looking on this board for someone who lives close to you that will give you a hand. remember, the secret to out trucks is the hole shot. hit him hard there. go neutral and hold the brakes while you rev it a little to build a little pressure in the lines. hold the pedal down hard. It will go down. put it in 3rd gear and build up boost all the while pushing the brake pedal HARD. and remember, even if you're not quite ready with the boost or whatever, when that light goes green... DON"T WAIT
GO!!
Also, our turbos make more power in the cool. your stock tranny is good for a pretty good launch even with the stock converter. spank him hard off the line and in the cool. and make sure it's it's in 3rd gear not overdrive. they run better there.
ask him if he'd like to race in a drizzle!!
I eat these things for lunch, but I'm not stock. good luck and let us know how you do
les
PS; if he wants to go from a roll out, (not in your best intrests) hold the brake down a little while you're building up some boost as you hold your speed. it makes a big difference when you get the turbo spooled up. improvise and conquer!!!
sound like I've done this before?
Me.
race on the street?
never
