late model suspension upgrade
Daveman2
Autox Blazer
Re: late model suspension upgrade
Ok that makes sense. So it was mostly for a brake upgrade. The bigger sway bar wont hurt anything either :tup:
I'm rocking the 4X4 33(or 34?)mm/28mm setup, and it keeps the truck pretty level:tup: They are a worthwhile swap.
ppress79
Installed the rear bar yesterday. WOW!!!!!! It now corners soooooo much better. Can't wait for coil-overs to finish this project.
I was at the salvage yard yesterday about to pull a front bar off a 4x4 Blazer. Luckily I went and measured mine first. It seems I already have 33mm front and 28mm rear on my '01 Blazer. I may go back in a lil while and see what else they have.
s_blazin
so to OP, did you leave your old torsion bars in? also since you have done this swap already, did it seem like the spindles on the newer s10 stuff would be able to be modified to use the f-body brakes?
i sold my coilovers due to needing funds for other things on the truck and now i have no front supsension, ans was thinking of going with the newer front end stuff.
i have f-body brakes already and would hate to do the swap or buy the parts only to find that the newer spindles won't accept the f-body brakes.
just wondering if it would be better for me to just go with the old style and use my old spindles that have the brakes already on them on update to the newer stuff, i guess it depends on whats needed for the brake swap
ppress79
I did keep the Sy tortion bars because anything else would be way too stiff. The hubs are the same diminsions. The only difference are the tone rings for the anti-lock brakes. The choice is debatable but I chose to do it since I had a late model donor handy and it was a cheap way for me to get the BIGGEST front bar available on mine since I live in hilly curvy SW Missouri.
Phil
Daveman2
Autox Blazer
Phil
the late model suspension does have nice swaybars(33/28mm), I'm glad I've never had to buy new ones cuz all the aftermarket ones are the same size or smaller. Other than that I don't see any upgrade except brakes possibly.
IMO I'd just buy a c/o setup again once you have the money, I don't think anything compares, but to each their own.
Looks like I only have a 23mm rear bar. I assumed it was 28mm and bought some poly bushings. Turns out it's not. I've only seen references to 28mm front bars, anyhow.
Daveman2
Autox Blazer
weird so you mean you can find one size 28mm bushings?
Was your 4by S10 a 2Dr? Did it have a heavy duty suspension package? Mine came with some crap like that.
Daveman2
Autox Blazer
I don't think I understand what you're asking.
Apparently 4x4 2dr LS Blazers (or at least mine) had some 'heavy duty suspension package' which was probably just a fancy name for the 4WD susp system.
I was just wondering what size the rear bar usually is, I have a 28mm I believe.
has anyone got poly endlinks for rear? The piece that goes into the frame is weird, I Was thinking of replace it with a rod end and running poly bushings on the sway piece of the end link. right now I only have poly with the 2 bushings around the sway, but the stock frame mounting bushing is in place, and it's beat to hell as it's never been replaced.
JAY
I rode in Erik's teal Typhoon (0966SY) & it rides nice with coils, almost like a sports car. I was impressed compared to my SY.
Daveman2
Autox Blazer
I'm going on the hunt for rear-endlinks for my car tomorrow, may end up with heim joints, which IMO would be great b/c then I could adjust the swaybar ends to the correct height so they level with the ground
overS-10ded
coil-overs are the best modification for sytys, dollar for dollar.
they make the trucks handle and perform, instead of roll like a regular s-series truck.
I have bought the coil-overs and am installing them now, however I plan on doing some light 4x4 as I described to Jax when I ordered, along with driving the wash board gravel roads that cover 3/4 of Montana, so I HOPE they are going to hold up....the upper shock towers are fine, not my concern here. I really got excited about all the space freed up by removing the torsion bars!!
I'm doing my rear now too, '91 housing, installing a Torsen, and looking at late model rear discs, to match my late model front disc conversion. I've read a lot of threads and looks like one needs to trim the flange on the housing and drill a couple of holes for the new backing plate that the caliper attaches. I have also heard of having to space the caliper with washers to index the caliper on the rotor too. I guess I'm hoping for clarification on these rear disc conversion steps.
As for my late front, the sway bar I got is 33mm supposedly, although I measured and comes up 34mm! My 33mm energy suspension sway bar mounts (listed for '98 up) need to be massaged a little to fit, or else they need to really clamp down with much tightening maybe. I'll torque them down today to see if the gap closes up all the way.
Thanks,
Bruce
Thanks,
Bruce
My front bushings didn't close up until I took it on the test drive after installation.
ppress79
My QA1s arrived today. I stumbled across a shop having a clearance sell for $290.00/ pair and I couldn't pass them up. (sorry Eric) II will get the springs next week end then start on the install. Will post on the ride after I'm done.
Phil
EcSy#2671
Si vis pacem, para bellum
Phil
Does that shop have any more??
BigBadSmoosh
buy from our vendors, without them there wouldn't be this kit.
I'd rather pay the $20 extra to someone i know then a stranger.
ppress79
you're right, I'll send mine back and will wait till next year to do mine.
Phil
:bigfinger:bigfinger:bigfinger
