--SyTy Jim--
GAST Member
Hey guys, here I go again. I'm going to do my garage SyTy style, just like my last one.
Here is the opener that I'm going to install. The Liftmaster 3800. I have read about it and I'm going to go with that model versus the i-Drive from Wayne-Dalton. I had the i-Drive in my other house, but heard from the new owners a few glitches they ran into. Also, my door is much bigger and not sure if the i-Drive would be able to handle it.
Liftmaster 3800
Here is a little write-up on it from the website:
Today's garages go far beyond a place to merely park your car. So no matter if you want the extra storage space up above, have an oversized garage door, or even a cathedral ceiling, the LiftMaster® model 3800 Residential Jackshaft Opener is perfectly engineered solution to fit your specific garage door opener requirements. It mounts easily on the wall beside the garage door, and comes with a remote 200-watt light that can be positioned anywhere in the garage. The optional EverCharge® Standby Power System – that continues to operate your opener even when the power goes out – makes it even more convenient.
Jimmy
Liftmaster 3800
- Powerful 24V DC motor provides ultra-quiet operation, along with variable speed smooth start and smooth stop
- Easy wall-mount installation means no rails to hang
- Auto-force feature constantly monitors garage door system and adjusts forces to temperature fluctuations, floor height, and door track movement
- The Smart Garage Door Opener® lets you electronically program security codes from the Smart Control Panel® or the powerhead
- Enclosed gear case provides continuous lubrication and protection for longer life and smoother operation
- A 6-foot power cord makes connecting to a power source easier than ever
- New optional Alternate Power Source (580LM) is a safe, permanent option to power the 3800 when an outlet is not within 6 feet; UL approved
- Remote light delivers 200 watts of light with adjustable light time delay
- Meets all UL325 requirements
- The Protector System® safety sensors project an invisible light beam across the garage door opening and automatically reverse the door if anything interrupts the beam while the door is going down
- Sensing technology will stop the door from closing if contact is made with a person or object
- Opener light turns on automatically when The Protector System's infrared beam is broken
- Security+® rolling code technology assures a new code is sent every time the remote control is used
- Manual release handle in case of power failure
Jimmy
