Mystery Wiper...Switch replacement?
Frank
Have the mystery wipe problem (windshield wipers sometimes activate without even touching the wiper lever). Realize I have to replace the steering column switch. Guess it's the one that the lever is attached to. Looked at the service manuals on CD. Got to be a Pita. Anyone with experience that will give me some pointers before I start taking my steering column apart?
Thanks
TyMeUp
One big thumbs up and nice pics too.
Not to take anything away from the great job you did, but could I suggest a small correction?
Steps 13 and 29 should say 'key-in buzzer/tone' switch. The horn contact is actually a button on the turn signal switch. This would be needed if someone were looking at this while trying to fix their horn circuit.
Also a tip. Tie a piece of mechanics wire to the end of the harness connector at the bottom of the steering column. Now, after taping the connector back at a right angle to the harness, you can pull the harness out through the top, taking the wire up also. Next, attach the wire to the new switch harness and tape its connector back. Pull the wire and new switch harness down through the column and you're done.
Again, great job on the write-up and pics. This group needs more of these.
