Anyone know of a good shop in S. FL? I need to talk to someone who knows this engine. I have a shop that maybe taking me for a ride.
The main questions I have is:
1.Can you use another 4.3 motor in this truck? They said it won't work because the Sy is an even fire crank and the regular 4.3 is an odd fire. I've never heard of this. I also see posts of other people using these engines.
2.Can you scope the cylinder to tell if there is piston / wall damage.
3.Can you put oil in the cyl with low comp. pressure to help id if it's the piston rings? If the pressure doesn't change it's a head/valve issue.
