0966Sy
Code what?
I just want to say i will appreciate all the help i can get, becuase i have never wired electric fans before in my life and have no clue what wires go where, what relay's, and fuses to use. Any options are appreciated, here's what i got.
Dual ramcharger fans on stock radiator, fit's awsome with a little modification. Thanks to Brian Green for his topic on these fans.
165 Amp altornator
50# Ultimate with the IC pump trigger at 160/not using this, went A2A
optima red top in the bed behind the cab.
I realy would just like to have the fans come on when ever i turn on the ignition, no switch, so they will just be running when the truck is also. A simple wiring diagram would be most appreciated.
Thank you,
Erik
165 Amp altornator
Thank you,
Erik
