helfmann
Cheers all together.
A battle currently two issues
1.) My needles don’t glow anymore, I guess (but it’s not more than that) that something is wrong with the plated wiring which connects the dash to the power and sender line. When I installed my face plates (speedhut) it was somehow cramped at the left side. Does one have a plan which one is feeding the needles with power when the light is on OR can this part purchased separately?
Btw the needles worked fine for over a year AFTER I installed the faceplates!
2.) My brake lights don’t work anymore. I run LED’s in the rear (ledtronics drop in replacement for 1157 bulbs) and since 4 weeks my brakelights don’t work anymore. Rear taillight and turn signal works, so the functions of the 1157 are present. Bought a new brakelight switch but …. no success. May alarm will lock the truck automatically on the first tipping of the brake pedal, this works and can be activated and deactivated but no brakelights. Questions: Does the second switch with the vacuum line attached (guess it’s for the cruise control) also triggers the light (there are some connectors on it) or just the CG.
I HATE car electrics!
Thanks
M@
Thanks
M@
